2006 Registrar Directory
Download directory
Registering your organization to the appropriate standard--and then following up with audits to ensure compliance--is one of the most important elements in any quality assurance system. Finding the right registrar, however, can be a tricky process. Quality Digest's 2006 Registrar Directory is the perfect place to begin your search.
The following directory includes almost 60 registrars' names, addresses, phone and fax numbers, Web addresses, and--for those companies that supplied one--a listing of supported standards.
As with all Quality Digest guides, the 2006 Registrar Directory is in no way meant to endorse or exclude any particular organization. Rather, it's meant to be used as a starting point in the data-gathering process. Readers are encouraged to contact the companies directly for more information and to ask for--and check--references.
More information, including registration service descriptions and a searchable (by company name, state, region, standards supported and industries served) database of all registrars in this directory, is available at www.qualitydigest.com/directories.
