Lean Toilets and LEED
Finding the waste that’s hidden in plain sight
William A. Levinson
Levinson Productivity Systems
Tue, 08/26/2014 - 11:00
Can something as simple as a toilet support LEED (Leadership in Energy and Environmental Design)? We take this basic sanitation device for granted, and while it makes the obvious wastes disappear very cleanly, another form of waste hides in plain view.
LEED already promotes the use of greywater, i.e., water that is unfit to drink because it has been used for bathing, laundry, or dishwashing, but has not come into contact with human waste. A greywater system makes the water work twice by reusing it to flush toilets, or irrigate landscaping (the concentration of hand or bath soap, or laundry or dish detergent, is apparently low enough to permit safe application to plants). This reduces the cost not only of purchasing water, but also of disposing of sewage.
Submitted by umberto mario tunesi on Tue, 08/26/2014 - 17:24
What's real gold?
Is it what is being dug from the ground? Is it oil? Or is it water? My parents and my grand-parents - to my memory - were very careful in not wasting water, they collected rain to water their vegetables and trees, and the dishwashing was done by hand, which uses less water and detergent. The website WaterFootprint Network shows impressive figures of water consumption to make daily drinks such as coffee and tea, and we all know that growing maize / corn, that's commonly used to feed cows, requires huge quantities of water, the quality of which is usually drinkable. Also growing eucalyptus trees to make "green" gasoline uses much water. Though I'm quite ridiculed for using the water used to rinse my flat's floor to water my plants or to flush my WC, may be adding some sodium hypochlorite, I keep doing it. Water is not simply "water": it has many a quality, from drinkable to demineralized to waste, and so on; we've to be more aware of these differences.
Submitted by umberto mario tunesi on Tue, 08/26/2014 - 19:26
one more comment - may be two ...
As a general, though generic observation, there's a common trend to undervalue / underestimate recyclability of valuable materials, and not of materials only. The "use and scrap" way of thinking is still too common, it has to be reversed to some kind of "think before you print" mentality. Is EVERYTHING we routinely do and use really necessary? Speaking of water again, why to let it run while brushing teeth instead of closing the tap and make water run to rinse the teeth? There are - may be - million examples of possibly recyclable materials - and ideas, documents, from plastic bottles to make toys to garments to make upholstery, and so on: the only hindrance is to view recyclability as a wealth demonstration, not its opposite.
