The 6-Percent Solution
Corporations can reduce greenhouse-gas emissions through better planning
Peter Dizikes
Tue, 11/23/2010 - 04:30
Nearly 6 percent of greenhouse gases generated by humans are due to the flow of products to consumers. David Simchi-Levi, a professor in Massachusetts Institute of Technology’s (MIT)  Engineering Systems Division and Department of Civil and Environmental Engineering, suggests that corporations could significantly lower these emissions by systematically analyzing their supply-chain logistics. Not enough companies analyze their emissions data in a thorough way, he says.
“This is a big problem,” says Simchi-Levi. “If you just do back-of-the-envelope calculations about logistics, supply chains, and emissions, you can arrive at misleading conclusions.”
In his new book, Operations Rules (MIT Press, 2010), Simchi-Levi outlines a variety of ways companies can improve their logistics—in particular, by using data and analytics to reduce the effect of supply chains on the environment. Consider “food miles,” the distance a food product travels to market, a common statistic aimed at measuring sustainability that is sometimes useful, but sometimes deceptive as well, asserts Simchi-Levi.
Submitted by gottohavetruth on Wed, 11/24/2010 - 06:41
Global Warming is not the end game.
I live in Lansing MI and we have lost a ton of manufacturing and most of the commercial air traffic that supported it at our local airport. We are way ahead of this 6% curve. How about you?
ASQ need not quash any more jobs in my area do to the HOAX of Global Warming that is being perpetrated on our nation. I'm sure that Peter Dixikes makes points in his article not based on the Facts that I see. These few links will direct you in the truth as I have seen it.
I would have anyone look at this to see numbers that you may not see any where else.
http://www.ncpa.org/pdfs/GlobalWarmingPrimer.pdf
FOX News Network and Glenn Beck expose the BIG picture and what is behind all the Fuss.
http://www.foxnews.com/story/0,2933,591830,00.html
I looked into all this over the last 2 years when it first came to my Very Liberal and Progressive part of the nation. Take a Look at this and see what 6% gives you:
http://www.coolcities.us/
Lets all just pat these people on the hand and tell them how nice they can write and get back to work fixing the real problems we face and not waste our time on this 6% BUNK.
Johnny Freedom
