Resources
Back Issues
by Denise E. Robitaille
It's almost inevitable: When conducting an ISO 9001 audit, everyone seems to miss something. For example, when one reads "calibration" in the standard, the mental image this conjures primarily involves micrometers, depth gages and comparators. The intent of ISO 9001, however, goes much further, aiming to ensure appropriate control of all the applicable devices that are used to measure, verify, test and accept products, and to monitor the processes used to achieve specified results. This runs the gamut of measuring tools, gages, samples, jigs, pH meters, test software, oscilloscopes, torque wrenches and the like. In each instance, it's necessary to adequately assess the use of the device and establish controls that are appropriate.
What follow are comments and suggestions based on audits conducted during the course of several years. Findings have included issues relating to:
Inadequate documentation
Missed instruments
Inconsistent implementation of the process
Misunderstanding the concept
Incomplete records
This process involves the company's control of the devices used to ensure that customers don't get defective product. Although ISO 9001 lists several requirements, it's also written to reflect consideration that calibration and maintenance vary in different industries. Unfortunately, this limits the amount of guidance that companies get in implementing this important process.
Following is a checklist of what needs to be considered. Not all points will apply to your organization. For some companies, only a few will be relevant. It's important to ensure that the instruments and devices you use to make decisions about product acceptability are adequately controlled.
Whatever document or procedure you develop to describe and define your process needs to be applicable to your company. Quantity, sophistication and instrument types vary greatly. Redundancy in the inspection process, duplicates of measuring tools and customer requirements also contribute to decisions on how to control your instruments and the processes you use to maintain them. There's a lot of diversity. Make sure your procedure describes what you do.
Define the frequency. It may be different for different types of tools. Scheduled calibrations need to make sense. It has to be obvious to the auditor that you've considered manufacturer recommendations, usage and any other internal factors. It's OK to have a three- or five-year calibration cycle if you can justify it with proof that the gage or device doesn't require more frequent checks.
For example, thread gages and plug gages are often put on a calibration cycle by usage rather than a fixed schedule. When a gage is checked out, the number of pieces that are verified/inspected during the job is recorded on the router. After a specific number of inspected pieces, the gage is recalled for calibration.
Some companies simply count days in service, which is also acceptable. Whatever you decide, make sure you stick to your defined process.
Try to avoid using only the month and year in your schedule, especially if the tool is critical and on a short cycle. Also, be careful when inserting a default into your procedure that says you can exceed the calibration date by a specified number of days. Combined, these practices can leave you with tools that are months beyond their recommended calibration cycle.
Consider the following scenario: A Vernier height gage is on a four-month cycle. The procedure states that there is a 30-day grace period beyond the calibration due date noted on the sticker. The schedule lists only month and year. The gage is calibrated on April 2 (04/2002) and is due for recalibration 08/2002. By rights, that should mean Aug. 2. On Aug. 28, the quality control technician decides to exercise his 30-day option. The tool doesn't get calibrated until Sept. 30. On Sept. 29, the gage was 58 days beyond its calibration due date and 50-percent through the next cycle based on its four-month cycle.
Sometimes this isn't a big deal. It depends on the criticality of the tool, prior records of calibration and any redundancies built into the inspection processes.
Perpetuation of this kind of practice or abuse of default grace periods erodes users' appreciation of the significance of the quality process's requirements.
Indicate if you have tools that are for reference only. You don't need to label every tool. But you do need to describe how everyone knows if a tool is not to be used for product acceptance. It's OK to say that tools that are not marked are assumed to be uncalibrated. That requires you to be more vigilant in making sure labels don't fall off so that your tools don't get mixed up or used improperly.
Make sure the labels are legible. If the labels on the tools are the primary record of the calibration and the only accessible vehicle for communicating the tools' status on the production floor, people must be able to read them.
Ensure that the company to which you outsource calibrations is included on your approved supplier list. If it has a certificate of accreditation, get a copy. If the company's accreditation is subject to periodic renewal, make a note to ask for a new copy when they get it.
If you do in-house calibrations, make sure you have a document that describes the process.
This doesn't have to be elaborate. It can be the manufacturer's recommendation for calibration, a bulleted list, a form, a flowchart or a brief procedure. It should describe the:
  • Standard to be used
  • Environment
  • Method
  • Acceptable limits
  • Process for adjustments
  • Record retention
Again, if you're doing in-house calibrations, make sure that the standards you're using (often a set of gage blocks) are calibrated using a standard traceable to the National Institute of Standards and Technology.
It's perfectly acceptable to say that certain gages (like special jigs) are verified prior to each use. Just make sure that the operators or inspectors can describe how it's done and that they're using calibrated devices for the verification.
It's also acceptable to say that certain devices are never calibrated; steel rules and tape measures are typical examples. You may state that they are periodically checked and discarded if they're found to be damaged or worn. Make sure you can back this up.
Review the certificates of calibration you get from calibration houses. Certificates of calibration are quality records. It's not uncommon to find errors or omissions on certificates. Verify that the tool ID numbers are correct and the date for the next calibration matches your schedule.
The certificate should state the results of the calibration, the standard used (tool or device) and the date it's due for recalibration.
The calibration house may state that detailed records of actual results are available upon request (rather than included with the certificate). Thisis something that should be periodically verified; consider it part of your supplier-monitoring program.
The instruments you're using for inspection should be adequate for the measurements you need to take.
This actually dovetails with the need to verify capacity as part of the contract review process. You need to ensure, especially with new customers, that the tolerances they require don't exceed your measuring-tool capacities. Your internal auditors can help with this. As part of the audit, they can select random prints on the shop floor and verify the accuracy (i.e., number of decimal places) of the micrometers and other gages that are being used for the job.
Instruments need to be properly stored. Auditors notice when tools appear to be poorly maintained.
If a scale is off by a known amount, it's OK to use it, provided the variation is communicated to everyone who is using it. Be prepared to prove that it is.
You need to be able to assess the integrity of test software or electronic devices that are used for product acceptance. How well-protected is the software from inadvertent adjustment? Would you be able to tell if the files had been corrupted?
If color is a measurable attribute of your product, you must protect your test samples from fading or discoloration.
When the device that you use for product acceptance is a specially designed jig or a "known good" sample, make sure that it's revised when there's a design change. You might want to make it a step in the design process.
If your product's integrity can be compromised by extreme temperatures or excessive moisture, you need to verify or calibrate your thermostats and barometers. How critical is the accuracy of the oven? What happens if the material stored in a freezer rises above a certain temperature?
Don't forget to calibrate gages that are used to control processes. Often an operator will set up a machine and make adjustments until he or she gets an acceptable first piece. The machine is then allowed to run with minimal product inspections. It's logical to assume repeatability if there are no variations in the machinery. Therefore, the automated process, rather than an inspection, monitors product quality. In these instances, any gages on the machinery (e.g., pressure and temperature) need to be considered for calibration in order to ensure adequate control of the process.
Have a contingency plan when you suspect that nonconforming product might have been released to the customer because of a faulty gage.
This doesn't mean an automatic recall procedure; it means that there should be criteria for deciding when to contact the customer. It should include such considerations as:
  • Was the product that was accepted using an out-of-calibration instrument shipped out?
  • If the product was shipped out, would the defect be obvious to the customer as soon as the product was received?
  • Would any undetected (potential) nonconformance have rendered the product unusable?
  • Would the defect have been detected at another inspection or operation before it was shipped out?
  • Does the potential defect affect the function of the product? Can you get a concession from the customer?
  • Do you need to recall all products immediately?
  • Do you need to alert any regulatory agencies?
Give thorough consideration when documenting this process. If your measuring devices are relatively uncomplicated, you don't need an elaborate and cumbersome procedure. Describe what you do and then comply with whatever procedure you ultimately develop.
Denise E. Robitaille is a consultant, writer and trainer. She is also a lead assessor and certified quality auditor. Much of her work involves assisting companies with implementing and maintaining ISO 9001-compliant quality management systems. She is also the author of The Corrective Action Handbook, The Preventive Action Handbook and The Management Review Handbook, all available from Paton Press (www.patonpress.com).
Letters to the editor regarding this article can be sent to letters@qualitydigest.com.
