Eliminating Defects in the Vertical Supply Chain
Root cause analysis can turn an emotional free-for-all into constructive problem-solving.
Chris Eckert
Apollo Associated Services LLC
Tue, 12/02/2008 - 12:07
Manufacturers’ efforts to do more with less have resulted in purchasing departments sourcing cheaper products and parts, often from overseas. Such cost-cutting certainly makes purchasing look good to management. But the effect on quality professionals may be just the opposite: product or part defects, malfunctions or undesirable side effects, not to mention the challenge of producing high-quality end-products within narrow timelines and budgets. Many sleepless nights are a frequent outcome.
Because cost cutting and global sourcing are here to stay, how can quality professionals combat these monumental challenges? Root cause analysis (RCA), when fully utilized, can eliminate defects in your operations as well as defects that you inherit from suppliers, ultimately helping to maintain a satisfied and engaged customer base.
