How to Convert ANSI/ASQ Z1.4 Sampling Plans Into Narrow-Limit Gauging Plans
Reduce the amount of attribute inspection that must be done
William A. Levinson
Levinson Productivity Systems
Wed, 05/22/2019 - 12:03
Anthony Chirico1 describes how narrow-limit gauging (NLG, aka compressed limit plans) can reduce enormously the required sample size, and therefore the inspection cost, of a traditional attribute sampling plan. The procedure consists of moving acceptance limits t standard deviations inside the engineering specifications, which increases the acceptable quality level (AQL) and therefore reduces the sample size necessary to detect an increase in the nonconforming fraction.
