Former Toyota Quality Manager’s Thoughts on Historic Recall
Foresees that problem was design issue
Jon Miller
Tue, 02/02/2010 - 05:30
Editor's note: At the time this interview was published by Gemba Research LLC, Toyota hadn't announced a fix to the sticky accelerator issue that caused the company to recall approximately 2.3 million select vehicles. On Feb. 1, the company announced that its engineers have developed a solution that involves reinforcing the pedal assembly, which will eliminate the excess friction that has caused the pedals to stick. According to a Toyota statement, the problem was caused by "a friction device in the pedal designed to provide the proper “feel” by adding resistance and making the pedal steady and stable. The device includes a shoe that rubs against an adjoining surface during normal pedal operation. Due to the materials used, wear, and environmental conditions, these surfaces may, over time, begin to stick and release instead of operating smoothly. In some cases, friction could increase to a point that the pedal is slow to return to the idle position or, in rare cases, the pedal sticks, leaving the throttle partially open." In other words, a design issue as pointed out below.
