New Machine Vision Lighting for Industrial Processing
RGB models now offer 1.67 million possible colors
LATAB
Wed, 06/01/2011 - 10:20
(LATAB: Vällingby, Sweden) -- LATAB, the Swedish manufacturer of LED lighting systems for industrial image processing, is expanding its range of ring lights, dome, and coaxial lights by adding RGB models.
Each of the individual light channels (red, green, and blue) can be controlled separately using an individual controller. That makes a total of more than 1.67 million colors possible so the ideal light color is available for every application.
All ring and dome lights with an outer diameter of 102 mm to 348 mm and coaxial lights in dimensions from 50 mm × 50 mm to 145 mm × 145 mm are available in the new RGB model.
Of course, the lighting heads can also be ordered in the standard colors of red, green, blue, white, ultraviolet, and infrared.
Further information about the new LATAB lighting heads can be found at www.latab.net.
