New Hardy HIBSX Hazardous and Washdown Bench Scales
12 in. x 12 in., ranging in capacity from 10 lb to 165 lb (5 kg to 75 kg)
Tue, 05/31/2022 - 12:00
(Hardy Process Solutions: San Diego, CA) -- Hardy Process Solutions has announced a new line of bench scales that are easy to clean, low profile, and all stainless-steel construction. The HIBSX series offers simplicity and robust performance for light duty industrial weighing applications.
To ensure durability in industrial applications, Hardy has performed corner, overload, and cycle testing to more than 8 million cycles. The HISBX series is ideal for manual check weighing, piece portioning, counting, and adding minor ingredients to a process or a batch.
With an optimized internal “X” design, the scales reduce the time required to sanitize them while offering one of the lowest profiles in the industry at just 2.02 in. to 2.95 in. (51.3 mm to 75 mm adjustable). Hardy HIBSX bench scales come with RoHS compliant 304 stainless-steel hardware, frames, and platters. Users may choose between stainless-steel hermetically sealed IP68/69K C2 load cells or aluminum, environmentally sealed IP67 C2 load cells, depending on their application.
