µLinc Processor: Power and Efficiency
For integration with laser and ultrasonic measurement systems
LaserLinc Inc.
LaserLinc Inc.
Fri, 10/14/2011 - 10:24
(LaserLinc: Fairborn, OH) -- LaserLinc has introduced the µLinc processor, designed specifically for integration with laser and ultrasonic measurement systems. It has connectors for all system I/O conveniently located on the back of the unit, for scanning laser micrometers, encoder input, and an UltraGauge+ wall thickness system.
Adding the µLinc to one of LaserLinc’s measurement and control packages gives you a turn-key system that installs cleanly and quickly.
The µLinc also includes detachable screw terminals for digital inputs, relay outputs, and analog input and output. The unit uses standard computer components and runs LaserLinc’s Total Vu software.
Other options include dual-video output, dual-LAN ports (with UltraGauge+ installations), internal 24 VDC power, and redundant, fault-tolerant storage. The µLinc has a variety of mounting kits: rack, DIN-rail, handles, and rubber feet.
