Honeywell Launches Single-Line Scanner
For fast scanning of linear bar codes
Honeywell
Mon, 07/18/2011 - 16:14
(Honeywell: Morristown, NJ) -- Honeywell has launched the Voyager 1250g, a single-line laser scanner, for handheld, scan-intensive environments. It has a multi-interface design that provides a “plug and play” experience, and an easy-to-assemble stand for hands-free scanning.
The Voyager 1250g is optimized for fast scanning of linear bar codes, including poorly printed and damaged codes. The scanner features an extended depth of field, allowing users to scan out-of-reach items with ease. It supports all popular interfaces in one device, replacing the time-consuming process of scanning programming bar codes. CodeGate enables users to ensure that the desired bar code is scanned before transmitting data, making the scanner ideal for use in menu-scanning applications. Setup is simple, and the Voyager 1250g’s ergonomic design fits comfortably in most hands, reducing user fatigue in scan-intensive applications.
The device is compatible with Honeywell’s Remote MasterMind for scanning software, allowing customers to manage, update, and configure scanners from a single centralized location.
