Fast, Tight, and Repeatable Connections for Gauges or Transmitters
Flange connectors attach in seconds, adjust to thicknesses
FasTest Inc.
Tue, 05/10/2011 - 13:32
(FasTest: Roseville, MN) -- FasTest Inc. announces Cal Mate flange connectors to provide quick, temporary calibration connections for gauges, transmitters, and other devices equipped with sanitary, tri-clamp style fittings. CalMate flange connectors quickly attach to sanitary flanges in seconds and can be adjusted to work in applications with different gasket and flange thicknesses.
CalMate flange connectors are rated up to 300 psi. Three basic sizes are available for applications from ½ in. to 2 in. tube sizes, and connectors are compatible with tri-clamp style flanges. Featuring stainless steel construction, CalMate flange connectors deliver safe, repeatable connections and long service life. The connectors’ design also allows for closer center-to-center mounting of sanitary flanges on vessels. Compatible with the FastCal hose connectivity solution, changing from one size connector is accomplished in seconds without the use of sealants or wrenches.
