Explosion-Proof LED Tank Light
Cart-mounted light can be disassembled and passed through any common-size manway
Larson Electronics MagnaLight
Tue, 03/15/2011 - 15:04
(Larson Electronics LLC: Kemp, TX) -- Magnalight.com has added the EPL-16C-1MLED-100 cart-mounted, explosion-proof LED tank light to its explosion-proof lighting inventory. This tank light is approved for use in enclosed spaces and produces 10,000 lumens of light in a wide flood pattern. Designed with a removable 16 in. LED light head, and wheeled, nonsparking aluminum cart, this light can be easily passed through standard-size manholes and entryways, and produces enough illumination to cover 8,000 square ft of work space.
The new addition to Magnalight products provides operators in hazardous locations with an effective and versatile explosion-proof lighting solution for confined spaces. The LED light draws only 150 watts, is multivoltage-capable, and can be operated with 120 VAC to 277 VAC. The wheeled aluminum cart includes 100 ft of explosion-proof SOOW cord for convenient connection to power sources. The LED light head can be adjusted through 360° of rotation and 90° of tilt, providing users with an easily adjustable light source.
