Understanding and Using Discrete Distributions
Each has special properties that you should use for specific cases
Jim Frost
Fri, 11/30/2012 - 16:59
Previously, I’ve written about how to use Minitab to identify the distribution of your continuous data. That post prompted several questions about how to use and identify discrete distributions. If you are a quality improvement analyst who works with counts of defects or pass/fail inspections, you may be particularly interested in these.
In this column, I’ll show you how to use discrete distributions in Minitab statistical software. My next column will show you how to determine whether your data follow a specific discrete distribution.
Continuous vs. discrete distributions
If a variable can take on any value between two specified values, it is a continuous variable, and the values follow a continuous distribution. However, if the value can only take on a finite number of values, the values follow a discrete distribution.
Submitted by Dr Burns on Thu, 12/06/2012 - 12:21
Hypothesis
When will people learn that control charts are not hypothesis tests ?
Looking forward to Dr Wheeler's next article tearing Mr Frost to pieces.
Submitted by Ralph on Fri, 12/07/2012 - 12:41
In reply to Hypothesis by Dr Burns
Nice article
Nice summary
