Savvy Compliance Strategy Part II—Checking Compliance
KPIs can reduce the need for manual process audits.
Sal Lucido
Mon, 06/21/2010 - 06:00
In Part I, “Savvy Compliance Strategy Can Improve GMP,” we took a high-level look at a process for automating regulatory compliance management. The closed-loop process starts with documenting your processes, followed by monitoring or checking that the processes are being followed. Next, you provide a means of tracking or logging any problems that may arise and then take actions to improve. Improvement should then result in a revision to the documented process followed by notifying or training those affected by the process improvement. This closed-loop process, which I call the “Circle of Compliance,” should be used to automate compliance with regulatory standards (see figure 1).
Figure 1: The Circle of Compliance
Submitted by AssurX on Tue, 07/13/2010 - 16:06
Part III is now available
I you liked Part I and Part II, Part III is now up online. You can read it here: http://bit.ly/axZjqs
