Quality Distribution in Manufacturing
A lean, transparent process
Thomas R. Cutler
Mon, 08/21/2006 - 22:00
The key to quality throughput within a warehouse, especially in a high-speed/high-volume environment, is the ability to move a carton into and out of a pick zone expeditiously.
When a warehouse control system (WCS) doesn’t process the information to divert products quickly enough, it causes cartons to be recirculated on the conveyor. This diminishes effectiveness, efficiency and quality control. Software must allow for consistent high-quality throughput, eliminating recirculation with effective communication between the WCS and the programmable logic controllers (PLC).
To achieve quality order fulfillment, the cartonization algorithm of a WCS selects the correct-sized carton for an order before the pick-and-pack process begins. The elimination of repacking is a central component in quality distribution: When the number of “touches” of the product is drastically reduced, quality control becomes lean and quantifiable.
Implementing a WCS with cartonization and zone skipping reduces the number of touches because of:
