Ford’s Five-Year, Global Waste-Reduction Plan
The automaker aims to cut waste-to-landfill by 40 percent per vehicle by 2016
Ford Motor Co.
Tue, 03/05/2013 - 11:13
Cutting waste-to-landfill at Ford Motor Co.’s Van Dyke Transmission Plant has always been important to workers there, but they weren’t satisfied until last fall, when a small, diligent local committee played a major role in solving a nagging 10-ton problem.
The solution, which keeps 10 tons’ worth of 8-ft-long, 350-lb fabric coolant filters from being landfilled monthly, means the Van Dyke facility is Ford’s first North American zero waste-to-landfill transmission plant and now diverts a total of 15 tons of waste-from-landfill monthly.
Moreover, the solution exemplifies how Ford already is making progress on plans to reduce the amount of waste-to-landfill from its facilities worldwide, as outlined in the company’s new five-year global waste reduction strategy. Under the plan, waste-to-landfill will drop to just 13.4 pounds—or by 40 percent—per vehicle by 2016.
