Box-Cox Transformation in Regression: It’s Easy!
Making the data meet the assumptions
Cody Steele
Wed, 12/04/2013 - 16:37
For one reason or another, the response variable in a regression analysis might not satisfy one or more of the assumptions of ordinary least squares regression. The residuals might follow a skewed distribution or they might curve as the predictions increase.
A common solution when problems arise with the assumptions of ordinary least squares regression is to transform the response variable so that the data do meet the assumptions. Minitab makes the transformation simple by including the Box-Cox button. Try it for yourself and see how easy it is.
