Ultracompact Ensenso S10 3D Camera Is Universally Applicable and Cost-Effective
20 point clouds per second, maximum deviation of 0.6 mm at object distances of 50 cm
Wed, 08/18/2021 - 12:00
(IDS: Woburn, MA) -- Camera manufacturer IDS Imaging Development Systems shows that the use of industrial-grade 3D technology does not have to be expensive.
The Ensenso S 3D camera is particularly suitable for 3D applications that require budget-friendly, easy-to-integrate and industrial-grade camera technology. The new Ensenso S10 has an ultracompact, IP65/67-protected housing and generates 3D data using laser point triangulation, supported by artificial intelligence. This makes the camera suitable for a wide range of applications—and delivers robust 3D information even in low ambient light.
https://www.mymepax.com/pressdoc_files/44020/image/ids-ensenso-s-dimension-size-comparison_300dpi.jpg_ico400.jpg
