Stereoscopic Microscope for Industrial or Biomedical Applications
Airtight, anti-mold, and anti-electrostatic design compatible with wide range of working environments
Nikon Metrology Inc.
Fri, 03/25/2011 - 09:30
(Nikon Metrology: Brighton, MI) -- Nikon Metrology has introduced its latest stereoscopic microscope, the SMZ-745. The airtight, anti-electrostatic, and anti-mold design of the microscope prevents samples from being damaged by electrostatic discharge, as well as by contaminants such as dust and water. This design makes it an excellent option for use in environments where temperature and humidity are high and solid contaminants are prevalent.
Additionally, the microscope is optimized with the Greenough optical system, allowing it to reach a best-in-class zoom ratio: up to 7.5 times. The magnification ranges from 3.35X to 330X when combined with the auxiliary objective lens and eyepiece. It also has a total reflection prism, which results in bright, high-contrast images. In combination a superior working distance up to 115 millimeters and a trinocular optical head ideal for monitoring and as digital imaging, the entire microscope is ergonomically built to provide a better usage experience, no matter the scientific discipline.
