Slip-in-Your-Pocket Handheld Tachometer
Ergonomic design and 12 in. range
Ono Sokki
Thu, 03/24/2011 - 13:01
(Ono Sokki: Addison, IL) -- Ono Sokki Technology Inc. has once again created a new type of handheld tachometer, one that is completely ergonomic.
The new HT-4200 tachometer is small, thin, and lightweight, weighing less than 4.5 oz. Not only does it fit perfectly in your hand, it also slips easily into your shirt or pants pocket. Incorporated in this compact tachometer is a large, easy-to-read LCD display.
Measurement setup is as simple as applying a small piece of reflective tape or reflective paint to the surface of the object being measured. Simply aim the HT-4200’s red light beam at the reflective marker and an on-target indicator light will flash to let you know when you’re on target.
The HT-4200’s light beam has a range of 12 in., allowing measurements to be taken both quickly and safely with an accuracy of 1 rpm.
