Product News: Interchangeable Vision Frame
Turn your vision system into profit by increasing productivity with your fixturing.
R and R Sales and Engineering
Fri, 08/21/2009 - 14:10
(R&R: Grand Haven, MI) -- Inspect parts faster than ever before with R&R Sales and Engineering's vision frame and interchangeable subplates allowing for continuous inspection on your machine.
An aluminum frame is mounted to fit your vision machine stage. The frame allows subplates to be snapped into the frame for quick and repeatable positioning. Plates can be modular with threaded holes 10 mm or 0.50 in. on center or custom built specifically for the application of the part.
Each vision fixture is made with a precision acrylic base plate that allows for back lighting and a clear, clean look at the part from your vision system. Fixture base plates can be customized to fit your vision stage. The fixture base plates are alpha-numerically labeled for documenting your part setups. Components are also labeled with a part number for easy identification and documentation.
The R&R Fixture, with its multiple holes and various components, has the versatility to hold virtually anything. Steel stampings or machined parts can be held to the fixture with magnets, while various clamping methods are provided for aluminum, plastic, brass, and other non-ferrous materials.
Let us help you with your fixturing needs. We specialize in hard-to-hold small parts.
