Product News: High-Speed Camshaft Inspection Gauge
Graphic display allows operators to visually monitor throughput.
ADCOLE Corp.
ADCOLE Corp.
Fri, 05/07/2010 - 13:52
(ADCOLE Corp.: Marlborough, MA) -- ADCOLE Corp. has introduced a submicron accuracy camshaft inspection gauge that features a new graphic display that enables operators to easily see the tolerance throughput status in real time for high-speed production monitoring.
The ADCOLE 1310 High-Speed Camshaft Gage features a new graphic display allowing operators to visually monitor throughput with green, yellow, and red plots depicting in-tolerance, reaching control limits, and out of tolerance status.
Providing gauge-room accuracy on the production floor, this end-of-line gauge offers user-programmable measurement parameters, easy part set-up changes, 0.1 micron resolution per data point, and 3,600 data points per revolution.
Enabling the direct correlation between an audit gauge and the production floor, the ADCOLE 1310 High-Speed Camshaft Gage utilizes the same technology as all Adcole gauges and can process up to 200 parts per hour. It can measure 10 or more parameters including radius, profile, taper, crown, timing angle, diameter, velocity, acceleration, run-out, roundness, and concentricity.
