Product News: Handheld Manometer for Differential, Gauge and Absolute Pressure
Smart manometer brings high precision and value to hand-held manometer users.
Omega
Tue, 08/25/2009 - 15:26
(OMEGA Engineering Inc.: Stamford, CT) -- The OMEGA HHP350 Series smart manometer brings high precision and value to hand-held manometer users. Standard accuracy is ±0.05 percent full scale, including temperature effects, with ±0.025 percent full scale optional. Models are available for gage, absolute or differential pressure with available ranges from 58 mbar (28 inches of H2O) to 138 bar (2,000 psi).
Additional features for the HHP350 Series include min/max capture, adjustable damping rates, and user selectable auto shut-off time period. It can also document up to 240 readings automatically or manually. Saved readings can be recalled at any time.
SPECIFICATIONS
Accuracy:
HHP-351: ±0.05 percent FS (except
HHP-351-A: ±0.1% FS)
HHP-352: ±0.025 percent FS
Storage Temperature: -5 to 50°C (23 to 122°F)
Operating Temperature: -40 to 60°C (-40 to 140°F)
Temperature Effects: No temperature effect over the entire operating range
Engineering Units: Inches of H2O [select 4°C, 20°C 60°F], Psi, mm of Hg, cm of Hg, inches of Hg, mBars, Bars, kPa, kg/cm2, and user selectable scaling
