Product News: Durable, Corrosion-Resistant Stainless Steel Sensors
For long-life performance in high-temperature, high-pressure wash-down applications
Rockwell Automation
Rockwell Automation Inc.
Fri, 10/15/2010 - 09:20
(Rockwell Automation: Milwaukee) -- Two new families of sensors from Rockwell Automation address the most demanding applications in the food and beverage industry. These sensors withstand high-pressure and high-temperature wash downs, while offering excellent resistance to corrosion and damage caused by harsh cleansing agents.
The 42CS photoelectric and 871TS inductive sensor families feature stainless steel construction, extended temperature ratings, and IP69K enclosure ratings. IP69K testing replicates the steam-cleaning process typically used in the food and beverage industry. This testing requires the sensors to withstand spray pressure up to 1,450 psi and temperatures up to 176°F (80°C).
In addition, both sensor families have been subjected to and certified to pass chemical-compatibility testing by two independent labs, both of which are worldwide leaders in the development of cleaning and sanitizing products. In testing, the sensors were subjected to some of the most commonly used caustic cleaning agents and disinfectants in the food and beverage industry.
