Multisensor Technology for Large Measuring Ranges
Werth’s ScopeCheck MB can measure up to 800 mm in the X axis and 2,000 mm in the Y axis
Wed, 05/06/2015 - 13:49
(Werth: Old Saybrook, CT) -- The newly developed ScopeCheck MB from Werth Messtechnik GmbH is a multisensor CMM for the precise measurement of large-volume components in the shop-floor environment.
The measuring range of this series is up to 800 mm in the X axis and 2,000 mm in the Y axis. 3D workpieces with high point density can be scanned quickly with the Werth Laser Line Probe. Measurement of functional dimensions with tactile, image-processing technology or laser sensors is possible by integrating the Werth multisensor concept. Freeform surfaces are measured with the Laser Line Probe sensor in the same coordinate system.
WinWerth Measuring Software is intended to provide efficient and simple machine operation and features an ergonomic graphic user interface.
The measuring machine can be modified for future requirements after the initial installation.
