Multiconfigurable, Wet-to-Wet Differential Pressure Transducer with Remote Sensors
Designed to reduce labor and materials costs as well as setup time
Setra Systems
Mon, 02/13/2012 - 11:32
(Setra: Boxborough, MA) -- Setra Systems, a global designer and manufacturer of pressure measurement instrumentation for industrial, test, and measurement, HVAC/R, semiconductor, energy, environmental, medical, pharmaceutical, and meteorological requirements, has introduced the Multi-Sense 231RS, the industry’s first multiconfigurable, wet-to-wet differential pressure transducer with remote sensors.
With availability in conduit and cable versions, the Multi-Sense Model 231RS offers four unidirectional and bidirectional, switch-selectable pressure ranges. Each unit also features field-selectable output choices of true 4–20 mA, 0 to 5, 1 to 5, and 0 to 10 VDC, as well as push-button zero and remote zero capabilities and a jumper-selectable port swap. Units are both CE marked and RoHS-compliant, and feature an all-cast aluminum construction with NEMA4 rated housings. An optional LCD is also available for greater readability of measured values.
