LR-19 Series LVIT Inductive Linear Position Sensor for Factory Automation
Getting more sensor for less
Alliance Sensors Group
Wed, 01/21/2015 - 17:24
(Alliance Sensors Group: Moorestown, NJ) -- H. G. Schaevitz LLC, Alliance Sensors Group (ASG) has expanded its sensor product offering by adding a line of LR-19 Series inductive linear position sensors, which are contactless devices designed for factory automation and a variety of industrial or commercial applications such as motor sport vehicles, automotive testing, solar cell positioners, wind-turbine prop pitch and brake position, and packaging equipment. With their compact design, superior performance, and excellent stroke-to-length ratio, LR-19 sensors are ideal for both industrial testing laboratories and OEM applications.
Features:
• Contactless operation prevents wearout from dither or cycling
• 6 ranges from 25 mm to 200 mm (1 in. to 8 in.)
• 1 in. (25.4 mm) diameter heavy-wall aluminum housing
• Excellent stroke-to-length ratio
• 19 mm (0.75 in.) diameter anodized aluminum housing sealed to IP-67
• Radial cable exit version comes with swivel-rod eye ends
• Axial termination versions with either M-12 connector or cable
