Heatable Sampling Probe Facilitates Natural Gas Measurements
Prevents hydrate formation
Thu, 04/07/2022 - 12:00
(AS-Schneider: Nordheim, Germany) -- In natural gas storage facilities in underground salt caverns, hydrates can easily form in the pipes, clogging them and making regular measurement of the gas pressure massively difficult. To prevent crystal accumulations, there is the possibility of heating the gas—until now a technically complex procedure.
A development by AS-Schneider simplifies the procedure: The heatable sampling probe generates the necessary heat, prevents hydrate formation, and enables accurate and process-safe measurements.
The copper ball valve is robust and enables safe and efficient operation.
AS-Schneider has designed the heatable sampling probe to be compact. This makes it easy to install.
