“Dark Pulse” Laser Produces Bursts of… Almost Nothing
NIST foresees laser’s application for infrared-based communications and measurements.
NIST
Mon, 06/14/2010 - 06:00
(NIST: Gaithersburg, MD) -- In an advance that sounds almost Zen, researchers at the National Institute of Standards and Technology (NIST) and JILA, a joint institute of NIST and the University of Colorado at Boulder, have demonstrated a new type of pulsed laser that excels at not producing light. The new device generates sustained streams of “dark pulses”—repeated dips in light intensity—which is the opposite of the bright bursts in a typical pulsed laser.
Despite its ominous name, the dark pulse laser is envisioned as a tool for benign communications and measurements based on infrared light frequencies. The laser’s ultrashort pulses span just 90 picoseconds (trillionths of a second), making the device suitable for measurements on short timescales. Dark pulses might be useful in signal processing because, unlike bright pulses, they generally propagate without distortion. Dark pulses might be used like a camera shutter for a continuous light beam in optical networks.
