Controller Enhances Thermal Verification and Electronics Burn-In
Remote interface allows set up and transfer of thermal profiles, logging and viewing diagnostics
inTEST Thermal Solutions
Mon, 05/19/2014 - 15:33
(inTEST Thermal: Mansfield, MA) -- A new control platform, the TS Controller, for Sigma Systems’ cryogenically and mechanically cooled thermal chambers and plates has been introduced by inTEST Thermal. Burn-in and testing of components, sensors, and PCBs typically involves temperature cycling from two to four points, which can be time-consuming to set up and run. TS Controller provides touchscreen and remote interfacing to set up and transfer thermal profiles, view data and trends, and log diagnostics.
Setting up test parameters (from -185 to +500°C) such as set points, ramp speed, hold time, probe source, auxiliary ports, and number of temperature loops is faster over previous systems. Display status includes temperature data and trends for the device under test, the chamber and set points. Diagnostics such as cryo valve usage, ambient temperature, chiller and blower run times, and enclosure temperature assists with maintaining system performance. An optional independent fail safe protects units under test from damage.
