AW-Lake Flow Monitor Helps NOAA Measure Ocean Salt Content
Compact unit is ideal for industrial flow measurement where remote monitoring is required
Wed, 02/22/2023 - 11:58
(AW-Lake: Oak Creek, WI) -- AW-Lake is supplying flow monitors to the National Oceanographic and Atmospheric Administration (NOAA) for use on its research vessels as part of a process to measure the temperature and salt content of the world’s oceans.
NOAA previously was unaware when a pump clogged while taking in saltwater as part of its measuring process. Different types of plankton and natural seawater debris clogged the pump, creating inaccurate seawater readings.
An AW-Lake MX 9000 panel mount process monitor not only tracked the amount of seawater flowing into the pump but integrated output into the ship’s data-gathering computer. The monitor was calibrated to trigger an alarm onboard the ship if water flow rate dropped below a specific level.
“Whether it’s out on the open ocean or the open road, our products are helping different industries measure and monitor flow rates,” says AW-Lake general manager Mark Iverson. “In many applications similar to NOAA, it’s imperative that process operations run more smoothly and efficiently.”
