Affordable Profile Measurement Gauge for Steel Rolling, Drawing, and Processing
The profile measurement system has an accuracy of 5 µm and a measuring range of 1 mm to 50 mm diameter
Nextsense
Wed, 07/10/2019 - 12:00
(NEXTSENSE: Graz, Austria) -- Continuous monitoring of rolling and drawing mill production has become a critical factor in the steel industry. To keep costs for quality control at bay measurement expert NEXTSENSE developed an affordable profile measurement system, ATON Wire, applicable for long products with round cross-section, like wires, bars and tubes.
There is a vast array of applications for the ATON Wire in your steel mill and most of them are focused on optimizing costs for you. Monitoring dimensional accuracy over the entire coil length allows you to instantaneously inspect and deal with faulty products, thus increasing your product quality standards. Checking roll and die wear will make roll and die changes plannable. Using on-line measurement reduces the time for product changes. Eliminating sample cutting will reduce waste and therefore material costs. Furthermore, full documentation of the whole production process is ensured.
