3-D Scanning Helps Custom Gun Grip Manufacturer Improve Quality
3-D scanning gives gun-grip company competitive advantage.
NVision Inc.
NVision Inc.
Tue, 11/24/2009 - 04:30
(NVision: Coppell, TX) -- A custom gun grip manufacturer has substantially improved the quality of its products by using the MobileScan HD portable 3-D laser scanning system from NVision to reverse engineer the original grips. In the past, the manufacturer used a coordinate measuring machine (CMM) to define the geometry of the mounting surface of the grips. But the CMM’s inherent accuracy limitations made it difficult to provide the desired fit and finish. The laser scanner, on the other hand, captures millions of points, making it possible to define the mounting surface to a much higher level of accuracy.
Custom gun grips make it possible for individuals to select the configuration that provides the best handling, pointing, and recoil qualities. Custom grips also add a finishing touch that improves the appearance of a gun. Most custom grips are made from woods. Personalized touches, such as monograms or initials, can also be added to the grips.
