Review of Performance Testing Requirements for Photovoltaic Modules
Specific performance tests found in IEC 61215:2005 and IEC 61646:2008
Regan Arndt
Thu, 07/08/2010 - 09:21
As the push to alternative energy technologies continues, the demand for photovoltaic modules is expected to increase exponentially. This article describes the specific performance tests found in IEC 61215:2005—“Crystalline silicon terrestrial photovoltaic (PV) modules—Design qualification and type approval,” and IEC 61646:2008—“Thin-film terrestrial photovoltaic (PV) modules—Design qualification and type approval.”
IEC 61215 and IEC 61646 set specific test sequences, conditions, and requirements for the design qualification of PV modules. Other standards address the safety qualifications for PV modules, including IEC 61730-1, IEC 61730-2, and UL 1703, and are outside the scope of this article.
Performance testing under IEC 61215 and IEC 61646 requires a total of eight test samples, selected at random from a production batch in accordance with IEC 60410. Figure 1 and figure 2 show the sequencing of individual tests under each standard. Individual samples progress through different test sequences in parallel.
