Mission Support Overhauls U.S. Air Force B-52s using FaroArm
Aerospace reverse engineering and inspection
FARO
FARO
Mon, 12/14/2009 - 06:00
Mission Support Inc. has pioneered the combination of sheet metal fabrication and modern computer-aided design and computer-aided manufacturing (CAD/CAM) dimensioning technology for improved production capabilities. They have also been leaders and innovators in the implementation of real-time CAD/CAM digital inspection of U.S. Air Force legacy aircraft components.
As a depot-level overhaul service provider for the Department of Defense and some of the major commercial aerospace companies, Mission Support has been engaged in the repair, overhaul, and manufacture of aircraft subassemblies since 1990, including airframe structural components, flight controls and the associated actuation systems, landing gear, and other flight-critical components (e.g., for aerial refueling). Based in Clearfield, Utah, Mission Support is an AS9100- and ISO 9001-registered manufacturer and maintenance/repair/overhaul facility, as well as a certified FAA Repair Station.
