Leitz Precision CMM Ensures Accuracy of Gear Grinding Machines
Leitz PMM-C Ultra meets exacting requirements of Swiss manufacturer.
Fri, 01/22/2010 - 14:25
Reishauer AG is a company with a long tradition in the gear industry. Reishauer’s products range from tooth profile grinding machines, to diamond and CBN tools, which the company exports to industrial states throughout the world. Teeth on gears with a diameter of 150 mm to 1,000 mm are given their final super-accurate grind on Reishauer’s highly precise machines, therefore it is critical that the inner workings of Reishauer’s grinding machines run as smooth as clockwork.
Figure 1: Ultra-high accuracy: the Leitz PMM-C Ultra in the inspection room provides an accuracy of 0.4 + L/1,000 microns.
With approximately 11,000 measuring devices—from small calipers and gear measuring machines to 3-D coordinate measuring machines (CMM)—Reishauer is in full control of the quality of its products. That is why, at the Wallisellen factory in Zurich, the quality assurance department has relied on Leitz for the inspection of their machine components for more than 20 years.
