Eight Tips for Optimal Machine Vision Lighting
How does lighting affect a vision application?
Microscan
Mon, 07/11/2011 - 14:28
Machine vision systems rely on quality images for quality output. High-quality images enable a system to accurately interpret the information extracted from an object under inspection, resulting in reliable, repeatable system performance. The quality of the image acquired in any vision application is dependent on the lighting configuration: The color, angle, and amount of lighting used to illuminate an object can mean the difference between a good image, resulting in good performance, and a poor image, yielding poor results.
