How to Influence Without Authority
No more, ‘Do it because I told you so.’
Jesse Lyn Stoner
Tue, 04/30/2019 - 12:03
Back in the good old days, if you were in a position of authority, you could just announce what needed to be done and assume it would be carried out. But times have changed.
As companies expand and become more complex, no matter what organizational structure is in place, people must work with each other across reporting lines. It doesn’t work to say, “Do it because I told you so.”
But were the good old days really so good? Hierarchical systems replicate parent–child relationships and create dependency. Worse yet, authority-based systems are a breeding ground for abuse of power and are prone to creating oppressive work environments.
Leading without relying on authority is a higher evolutionary skill. It supports developing adult relationships based on mutual objectives and creates work environments grounded in respect for human dignity.
