It happens easily enough and usually innocently enough. You start a business or organization then endure what is often a long and expensive learning curve. Along the way you learn. You learn a lot. You discover the competencies and incompetencies of those working with you. You learn how to manage cash flow challenges. You learn the ins and outs, the ups and downs of business in the real world.
In a few years, the business or organization begins to prosper. By then your role should change from working in your business to having more time to work on your business.
But too often it doesn’t. The business begins to prosper and could expand to another level, but something seems to be holding it back. (I use the term “business” in a very broad sense. Even nonprofits are enterprises with a mission to accomplish and must function in just about every sense as a business. The only differences are that the excess revenues received are not distributable to anyone except in the form of salaries paid for work performed.)
