Seven Strategies to Manage a Micro-Manager
Overcoming a frustrating rite of passage in the workplace
Victor Prince
Thu, 07/11/2019 - 12:02
If you work long enough, you will have a micro-managing boss or two. These bosses think they know your job better than you do. Maybe they had your job before they got promoted to management. They focus on how you do your job instead of on the results you produce. They think that because you are doing your job differently than they would, you must be doing it incorrectly. Micro-management is a big driver of dissatisfaction and attrition in the workplace.
Seven strategies to manage a micromanaging manager
Diagnose the situation. Is your boss micro-managing others or just you? It is important to understand whether you are being singled out, or if you are just one of many victims. If he micro-manages others, too, it’s probably him, not you. But if you are the only one being micro-managed, it might be you, and it is worth figuring out why. Perhaps your boss is just more interested in your job than others. Or perhaps he thinks you need closer scrutiny. If your boss’s micro-management is due to problems with your performance, you need to surface that discussion and address it head on.
