One hundred years ago this month, Walter Shewhart wrote a memo that contained the first process behavior chart. In recognition of this centennial, this column reviews four different applications of the techniques that grew out of that memo.
The first principle for interpreting data is that no data have any meaning apart from their context. Context tells us what type of analysis is appropriate, and how to interpret the results of our analysis. The following will illustrate this principle.
Observational studies
The immediate and most common use of Shewhart’s technique is with observational studies. Here, either an Average and Range chart or an XmR chart is used for the real-time, sequential analysis of a continuing stream of operational data. A baseline period is used to compute limits that define what a predictable process is likely to produce, and then these limits are used with additional data as they become available. Every time we add a point to our chart, we perform an act of analysis; the chart asks, “Has a change occurred?”
Every time we add a point to our chart, we perform an act of analysis—the chart asks, “Has a change occurred?”
Was this guy born in a barn?
Sorry, really struggling to get past the image of the guy with his SHOES ON THE TABLE.
Frankly, I blame the parents.
XmR Chart software
Donald Wheeler kicked off a movement for leaders at the 3M company when he delivered a presentation based on his book "Understanding Variation". In order to put his teachings into practice we developed an Excel Based Process Behavior Application that created Individual and Moving Range Charts, XmR Charts in Wheeler's lingo or otherwise known as Individual Charts. A newly released Excel Add-In called PBCharts PBCharts.com is available free for 90 days for you to try. View the 5-minute tutorial https://www.youtube.com/watch?v=zFpwP49zvrQ demonstrating a dataset used by Donald Wheeler to show how to Avoid Man Made Chaos. And yes, we named the software in honor of Dr. Wheeler's use of the term Process Behavior Charts
