Muda, Mura, Muri
You can’t eliminate waste unless you also deal with two other process concerns
Like your dad told you: A place for everything and everything in its place
Joel Bradbury
Wed, 03/08/2017 - 12:02
One of the most important goals of lean manufacturing is the elimination of waste. Taiichi Ohno, father of the Toyota Production System (TPS), defined three categories of waste: mura, muri, and muda. While muda is the most widely known, muri and mura are equally important to understand.
Submitted by dvanputten on Mon, 03/13/2017 - 10:25
Muda or Mura?
"While muda is the most widely known, muri and muda are equally important to understand."
I beleive the second reference to muda should be mura. I think there is a type.
Thank you, Dirk
Submitted by Taran March @ … on Mon, 03/13/2017 - 11:03
In reply to Muda or Mura? by dvanputten
mura it is
Good eye. We made the change. Thanks.
