Laser cutting is an essential part of many industries, from car manufacturing to construction. However, the process isn’t always easy or efficient. Cutting huge sheets of metal requires time and expertise, and even the most careful users can still produce huge amounts of leftover material that go to waste. The underlying technologies that use lasers to cut edges aren’t actually all that cutting-edge: Users are often in the dark about how much of each material they’ve used, or if a design they have in mind can even be fabricated.
With this in mind, researchers from MIT’s Computer Science and Artificial Intelligence Lab (CSAIL) have created a new tool called Fabricaide that provides live feedback on how different parts of the design should be placed onto their sheets—and can even analyze exactly how much material is used.
Fabricaide: a tool for less wasteful laser-cutting
