The engineer came into the statistician’s office and asked, “How can I compare a couple of averages? I have 50 values from each machine and want to compare the machines.”
The statistician answered, “That’s easy. We can use a two-sample t-test.”
“How would that work?” asked the engineer.
“We compute a t-statistic based on the difference between the averages, and if the p-value for the t-statistic is small, we’ll have a significant difference,” replied the statistician.
“So a small p-value means we have a big difference?”
“Not exactly. The size of the difference is always relative. It depends on the background variation. A significant difference is one that is detectable in spite of the background noise present. The actual difference may be either large or small. And a small difference may be of no practical importance,” said the statistician.
“So why not call it a detectable difference rather than a significant difference?”
“That’s just the language of statistics. We can’t afford to make things too clear because if we did, people might not seek our help.”
Question
In figure 2, why are UCL and LCL for the average chart not symmetrical around the center line?
