Teledyne Announces Ladybug6 Cameras
New model promises high-accuracy, 360-degree spherical image capture
Tue, 11/08/2022 - 12:01
(Teledyne FLIR: Richmond, BC, Canada) -- Teledyne FLIR Integrated Imaging Solutions presents its all-new Ladybug6, the latest addition to its field-proven Ladybug series.
Ladybug6 is the leading high-resolution camera designed to capture 360-degree spherical images from moving platforms in all-weather conditions. Its industrial grade design and out-of-the-box factory calibration produces 72 megapixel (MP) images with pixel values that are spatially accurate within +/- 2 mm at 10-meter distance.
“The new Teledyne Ladybug6 is designed for mobile mapping and all-weather inspection projects requiring excellent image quality and high resolution,” says Mike Lee, Teledyne FLIR senior product manager. “With the addition of Ladybug6, we are now pleased to offer a wider variety of spherical cameras with higher resolutions ranging from 30 MP to 72 MP.”
The new Ladybug6 builds on Teledyne’s machine vision heritage with increased image resolution, enhanced on-board processing, and robust IP67-rated connectors. Building on the field-proven Ladybug5+, the Ladybug6 captures, compresses, and transmits 8-bit or 12-bit pixel data, delivering outstanding images across a wide range of lighting conditions with excellent color response, low noise, and a high dynamic range.
