Hardy Rolls Out HIDS Industrial Drum Scales
Durable and easy to use
Mon, 08/26/2024 - 12:01
(Hardy: San Diego) -- Hardy Process Solutions has announced a new line of accurate, rugged, and reliable drum scales that provide value and flexibility in size and capacity for use in a wide range of drum weighing applications. HIDS drum scales are built to be long-lasting and perform well in heavy industrial environments, yet are easy to install and use with the latest advancements in weighing technology.
Hardy drum scales are available in painted steel with alkyd enamel paint and a tread deck or smooth deck in two sizes, 30 x 30 in. and 36 x 36 in. Each size comes in 500, 1,500 and 3,000 lb capacities. They feature access holes in the decks for load cell servicing and cleaning. With a deck height of just 1.5 in., they are easy to load and unload with an optional 12 in. ramp
Purpose-built accessories such as indicator columns, ramps, and Hardy swivel mount weighing instruments greatly extend the ease of use and application compatibility for a wide range of applications. Weight processors can be mounted on the indicator column or on a nearby wall for easy reading.
