Why Quality Is Now Aligned With Development at the Outset of Projects
Enter the quality advocate
Alison Hawke
Thu, 09/27/2018 - 12:00
Historically, quality in a process was something that was done at the end of the line. You inspected your widget once it was made, and if it had flaws, you fixed it or threw it out.
As in many modern manufacturing environments, quality in software has become a process you do from start to finish. Moving from that end-of-line quality control mindset to a more user-focused, whole-team quality advocacy helps deliver a better product where quality is baked in from the start, and part of the job of all roles on a software team.
Quality advocates start on the first day of a software development project and are now part of the development process from idea to final deployment. With the strengthened emphasis on quality, the title for quality professionals has rightly been designated as “advocacy” to display that someone is working hard, from conception to shipment, and is determined that a software development team will deliver a superior quality product or solution for the customer.
In other words, quality advocacy is now more of a broad-ranging activity.
