Strong Warehouse Wi-Fi Design Improves Robotic Material-Handling
Understand your Wi-Fi environment
Emily Newton
Tue, 05/23/2023 - 12:02
It’s increasingly common for today’s warehouse managers to pursue robotic material-handling solutions. That approach can boost productivity, reduce injury rates, and enable companies to adjust to changing demands. However, before company decision-makers choose what kind of robots they want, they must carefully analyze the warehouse Wi-Fi design and determine whether it aligns with the company’s current and future needs.
Many robotic material-handlers use Wi-Fi for basic functionality. Strong Wi-Fi in an environment that uses material-handling robots enables machines to learn and recognize their surroundings while avoiding obstacles. This helps them operate safely and effectively.
Managers can also use data-transmission capabilities on some material-handling robots to get real-time information about a machine’s location, total moving time, or other specifics. Users can access a database to see how robotic handling equipment contributes to a company’s operations. However, a spotty Wi-Fi connection can cause the robot to lose the necessary signal, causing it to operate erratically or stop moving.
