Scientists are striving to discover new semiconductor materials that could boost the efficiency of solar cells and other electronics. But the pace of innovation is limited by the speed at which researchers can manually measure important material properties.
A fully autonomous robotic system developed by MIT researchers could speed things up.
Their system uses a robotic probe to measure an important electrical property known as photoconductance, which is how electrically responsive a material is to the presence of light.
The researchers inject materials-science-domain knowledge from human experts into the machine-learning model that guides the robot’s decision-making. This enables the robot to identify the best places to contact a material with the probe to gain the most information about its photoconductance, while a specialized planning procedure finds the fastest way to move between contact points.
During a 24-hour test, the fully autonomous robotic probe took more than 125 unique measurements per hour, with more precision and reliability than other artificial intelligence-based methods.
